extrude - only one extrude to parts simultaneously possible?
stefan_mühlbacher
Member Posts: 5 ✭
Hi @ll,
this are my first tries in onshape - i try to remove the upper and lower part of a sheet with the extrude tool. Both extrudes work, but not simultaneously.
Please try to unsupress "cut lower part" in this public document:
if "cut lower part" is unsupressed, the "cut upper part"-extrude does not work anymore.
Anyone knows why?
Greets, Freisei
Optionsdick_van_der_vaart Member Posts: 51 PROHello Stefan,
Please take a look at Blech1-Copy document again, I did some editing.
Dick5
Welcom to this forum.
I made a copy of your document and tried a different approach in Part Studio 2, used only configurations.
Have a look,
https://cad.onshape.com/documents/3f8dc24dabf372e362e377e6/w/93c069e716be15ac3532878d/e/c4e64b7b960c62350e7dc928
Good luck
Dick
We are looking into improving robustness of such cuts.
Thank you for your patience.
