Simulate directly on Onshape models on the cloud with Intact app
Andrew_Taber
Member, Developers Posts: 4 ✭✭
Intact is a simulation tool built around making simulation easy and inexpensive by simulating directly on Onshape models. No installation, meshing, or preprocessing is necessary. We just released Intact on the app store, so check it out. It's free for now, and we'd love to hear your feedback on how to best fit your needs!
5
Thanks for giving it a try! We're definitely still iterating on our performance and usability Generally simulations take a couple of minutes, but there's also quite a bit of variability depending on the complexity of the part. If you're willing to share some more details, we'd love to take a look at the part that's causing trouble - just drop us a line at support@intact-solutions.com.
i ve test and it's really good and awesome.
Intact is really intuitive.
i've an education plan.
Intact will be just one month freely or with the education plan can i still use it after one month ?
thanks a lot
i am trying to use intact on the most simple onshape model. it does not work for me.
I just tried out intact, and while I have been able to get the results fairly quickly, the model itself is not visible for me to inspect the areas where stresses are high.
