Roller Bearing Mate
Can anyone advise if possible how to mate the roller in the URL below so that it rotates as the cage and inner race are rotated . I have tried following the solid works you tube video but after some considerable time cannot find the correct mates. I do think if it can be done in solid works there must be a way in Onshape.
Hoping someone can help , Regard Brian
(Can someone please tell me how to copy URL, done it before but not working this time)
KatieHuffman Member, Onshape Employees, Developers Posts: 194
There are some examples of this in the Learning Center, under the Mating Basics Tech Briefing. Look at the section Consistent Practices. There are two examples linked there, one with a Revolute mate driving the assembly and one with a Fastened mate.6 -
brian_pinder662 Member Posts: 119 ✭✭
Thank you for your reply, this has pointed me in right direction, feel like I am getting somewhere now.
Best regards Brian.
1
Best regards Brian.
