Sketching a circular pattern
ChuckKey
Member Posts: 45 ✭✭✭
I am having button trouble. I can't fathom out how to simply accept the origin default for the centre of the pattern. They always end up not fully defined.
billy2
Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,115 PRO
pick the circle pattern center, then pick something else, then hit the "i" key.
This takes the circle pattern's axis and locks it to what ever. Also, this is now the radius of the pattern.
I agree, it's not obvious how it works, but it does work. In fact it's fast.
It's weird that it throws this pattern down and then you need to lock it down. This is different than what I would expect and takes some getting use to.
I read the manual to get it working and played around with some simple geometry to get the hang of how it works.
I also believe that it won't pattern a spline which I wrote up yesterday. I haven't heard back if it is a problem or something I did wrong.
5
As far as interfaces go, when learning, it's nice to have the hints. But after you learn them, these get in the way. It's hard to say I don't want the help when learning. But, I do want the speed after learning. Probably more the speed then hints.
I do like the speed once I've learned. The sketch circle pattern seems to be the worse of the lot.
There's no answer here, just a little sympathy.
