Can you please go to https://cad.onshape.com/check and post the results of your Compatibility check here? It's possible that the browser you are using on your laptop is not utilizing your discrete graphics card or you could be having a driver issue.
Best,
Mike
set global settings for your browser (in my case chrome) to use the nVidia card instead of the intel chip.
I'm not showing nVidia on mine because I'm on my desktop and there is only one option for me
After you set those settings. Close and re-open your browser.
then do the system check again. you should see your discrete card there under "Renderer"
