Change Measurement Unit
famadorian
Member Posts: 390 ✭✭✭
When I started my document, I started with simple numbers like 9 and 15, but now I need to change them be be 9 meters and 15 meters. I see that they are 9 mm and 15 mm in the document. Is there any way to just convert the unit for the whole document?
Maybe it helps you
https://cad.onshape.com/documents/c3b16080102aca07dc7ebfaf
