Title Block - Fields Not Updating
mark_proulx
Member Posts: 48 ✭✭
in Drawings
I'm creating some simple drawings of parts that reside in a Part Studio. In the part studio, I give each part a number, material designation, and other part-specific properties. When I make a drawing of the part, I populate the fields of the title block with information extracted from said properties.
I have a drawing whose title block won't populate. The only difference between this drawing and the others that I've done is that when creating it, I declined the offer of default views and chose to specify my own.
When I attempt to populate the part number and material fields in this drawing, the application generates the default "---". I'm looking for some insight into why this is happening.
Here are some screenshots to illustrate the problem. In the first, I specify the part number
After I create the drawing, I attempt to populate the title block with the part number:
When I select "Part number," the default text appears:
https://cad.onshape.com/documents/08d8c039e8ef262fab6a06ef/w/49d724fd6fc4291a5272999c/e/07031bf0ecb33eaa2be8ecd9
It turns out that if you modify part properties after creating the drawing, the properties are not available for use in populating the title block. I created a drawing this morning only to discover that I had not specified a part number in the Part Studio. I added the part number to the part properties, but the information was still not available in the drawing. I trashed the drawing and recreated it; the part number information was now available.
