Use angles in sketches
Hey ev1 !
Does anybody know if is or will be possible to use an angle constraint that could work like the dimension one in skecthes ?
david_sohlstrom Member, Mentor Posts: 159 ✭✭✭
If you click on 2 lines in your sketch the dimension tool will give you the angle between those lines. You can then edit that angle to the one you need.
DaveDavid Sohlstrom
Ariel, WA5
Dave
Ariel, WA
Edit:
I would like to see angle also in offset for certain mate connectors, but creating new connector is easy so not very high priority on this matter..
