"non driving" dimension as variable?
alexander_potochkin
Member Posts: 45 ✭✭
Hello
Could you help me to understand how I can use a "non driving" dimension as a variable?
I have a square and a variable which defines this square by the length of its diagonal.
Now I need to use the length of the square's side as a variable for the next operation (say extrude).
Is it possible to do it in onShape?
Thanks!
Thanks!
1
lougallo Member, Moderator, Onshape Employees, Developers Posts: 2,001This is something we will add but was not in the first build of the feature. Currently you will need to use a variable to define the dimension you want to reference. More iterations to come.Lou Gallo / PD/UX - Support - Community / Onshape, Inc.7
https://cad.onshape.com/documents/c14f7a86f2624c8082b658cc/w/9757b49885644d65accd48d2
But is there a general way to take a dimension and use it as a source of another dimension?
Thanks
I put in a request a few days ago when I was trying to do this for the tetrahedron challenge.
Workaround would be creating enough parameters to be able to calculate equation for the driven dimension you need.
I used Creo and Inventor but have not seen the possibility where we are able to change the driven dimension manually. But it can be good enhancement comparing to other CAD platforms if Onshape could make it possible.
This should not be a problem, should it?
But after changing the diagonal the result will not be a square which has all sides equal to each other. It will be a rectangle with two opposite equal sides. We can put the length of rectangle side (driving dimension) as variable in extrude also.
See the below video. I hope this could be one of your requirements.
Website: ovyl.io
