Error Message says "Delete part 1 did not regenerate properly: Select parts to delete"
Why can I not delete the default geometries selected, even though there are "x" marks indicating that I can.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,970 image
    The error message indicates that you have not selected anything? You can only delete Parts (solids), surfaces and curves (in the parts list, bottom left).
