Extracting control point coordinates from spline curves
I'm modeling a roller coaster for export into a third-party simulation environment. In that environment, I will need to use a point-on-curve constraint to hold the passenger cars on the track. With this in mind, I'm wondering—is there an easy way to extract the control points for a spline curve in Onshape? (The track is based on a series of spline curves.) I can always open the sketches for the splines and use dimensions to get a sense of the control point coordinates, but I wonder if there is a more convenient way to do this. Thanks for whatever suggestions you can share!
