Expanded Metal
in General
I'm not sure I understand your question, could you go into more detail?
Here is a webinar from last year about our sheet metal features:
https://www.onshape.com/videos/designing-with-sheet-metal-in-onshape-051718
@kent_henderson or @Jon_Schlemmer did you come up with a solution?
then make it as thick as the maximum thickness
but if you really need the accuracy it will come at a performance cost.
I would draw the top of one of the diamonds in 3d the pattern it in two directions.
Then draw your cut out pattern and extrude/intersect thru to get your final result.
Lead Mechanical Engineer @ Healing Innovations
