Sweep deviates from specified path
I'm trying to sweep the rails of a roller coaster track along a spline curve. The rails need to pass through a series of connection plates so that the plates are centered on the rail cross section. To ensure this, I used the same spline curve to pattern the connection plates so that they fall on the rail path. Trouble is, when I sweep the rails, they deviate slightly from the specified path.
After some length, the connection plates are no longer centered on the rails as intended. By the end of the sweep, the connection plates don't even pass through the rails at all---this despite the rails and connection plates being based on precisely the same spline. Part of that spline is shown in the figure in orange. You can see that the bottom of the upright tubes fall neatly on that line while the spline veers upward sightly but noticeably.
The sweep profile is on a plane normal to the sweep path and located at the start of that path. The profile does not intersect the path but it doesn't seem unreasonable to expect that the sweep would try to respect the path nevertheless. Any thoughts on what could cause this?
Try editing the appearance of the part and setting the tessellation to very fine
Yes, I think the tessellation is making it appear different to what it should be.
