Sketch changed when mirrored
glib_kotelnytskyy
Member Posts: 23 ✭
I've versioned a documet that I'm having a problem with: https://cad.onshape.com/documents/d00ceaba15e3ae5795e20cc8/v/e1306259ed2b791bba55a81d/e/5b289bdfe74c787a08ec07e3
There's a sketch "Sketch 2", on a plane parallel to the "Front plane"
The angle between two lines of this sketch is as follows:
Then I've mirrored this sketch by the parallel mirror plane "Front"
And on the mirrored entity the angle between those lines is different:
How could it happen?
I've checked that all the vertical and horizontal lines on both sketches are parallel, but not the inclined lines.
NeilCooke
Moderator, Onshape Employees Posts: 5,927
That's very unusual. The construction line at the bottom is shorter and I can't see the reason for it, so it may well be a bug. Please open a support ticket (help > report a bug). As a workaround, create a new sketch on a plane where the mirror should be and "use" the geometry from the first sketch.Senior Director, Technical Services, EMEA5
Would it be to do with dropping external references?
https://forum.onshape.com/discussion/8603/option-to-not-to-drop-external-sketch-references-in-feature-pattern
EDIT: I take that back. Deleting the external constraint in the lower left corner fixes the mirror. The link you shared refers to a feature pattern limitation, whereas this presents itself as more of a bug, but it's the same thing. I will add this as a test case for fixing.
