Release Management - Workflow Procedure
APD
Member Posts: 40 PRO
Hi,
I'm thinking of implementing a new Project Release Workflow.
- Release part studios. (thereby all parts)
- Update assemblies with released parts ("Update to latest" so feature tree shows the black triangles)
- Release All Assemblies.
- Update all parts and assembly drawings so that they show released parts and assemblies.
- Release All drawings.
I've broken it down like this because doing everything from a single release candidate was troublesome. I was having to fix to fix too many issues - drawings pending update, assembly errors, part errors, duplicate part numbers ("this part was previously released from another document" where the document has been copied).
Also the candidate dialog list becomes very long. The two panes (left and right) do not quite line up (maybe just my Chromebook). So by the time you get to the bottom of the list, the misalignment causes confusion as to which part you might be editing/releasing (exacerbated by the fact I'm using the auto-gen arbitrary part numbers. )
Using the above proposed sequence I can more systematically correct issues with the project and have all of the drawings in a single release candidate (step 5).
Would be interested in any feedback.
1
Onshape, Inc.
If you submit a Drawing and all it's corresponding reference as a candidate: one would expect that drawing to have a "Released" triangle as reference for the release of the components.
The way Onshape does it you can basically release Rev A of a Drawing with all it's reference flagged as WIP and never released, which to me just seems wrong, or a very BAD practice in terms of Data Management.
CAD Engineering Manager
That is not exactly true because if you release a drawing it automatically includes the corresponding part or assembly. Drawings carry with them the parts that they reference to ensure that you do not release a drawing of a WIP part. Therefore if it is the WIP then it will revision that part/assembly as necessary. On the contrary, if you update the version of the part/assembly in the drawing to a released version then when you go to release that drawing it will display the revision of the part/asm that is being referenced.
The issue lies in that as Alexei has pointed out it makes more sense to release in multiple stages to better capture the data. I agree that a multiple stage release makes a little more sense, but is certainly cumbersome.
I've Designed an some parts, assembled them and generated a Drawing, now I'm ready to release everything. I'm done working with them. I generate my Release Candidate and everything looks ready, they will be 001 (Initial Rev)
The Release is approved and 001 shows in my History.
But what happens if I load Rev 001?
The Release intent was obviously to Release 001 of everything, which it did, BUT, the Assembly Released at 001 is referencing parts that where NEVER RELEASED (V1). This is a Problem! I understant the workaround (whinch requires 3 additional steps) but for Mid to Large Assemblies it would be a Pain
Sorry to sidetrack your discussion Alexei!
The below is based on a simple 3 part PartStudio, a single sub-assembly(assy 1), a main assembly (assy 2) with drawings for all.
Google sheet link here for anyone interested...
https://docs.google.com/spreadsheets/d/1R2J0zqQOsjj93d3L1QLufzX9ybZP49jL2drl0m_Nszk/edit?usp=sharing
The "Workspace" region on the left refers to what you would see in the Main workspace.
Even for this very basic project, it becomes very complicated to keep track of.
I think I will try and stick to just releasing everything from the one candidate where possible!!
As always, any comments welcome.
*Step2/Step7 of the above is a "fail" with sheet metal parts (which I use a lot) as when I release them from the part studio, it doesn't seem to take the flat patterns with them. So the flat pattern views in drawings don't update (it could be just my ineptitude; I have a ticket out for it)
To keep data management simple, we could simply refer to the workspace version, with everything referencing MAIN.
Workspaces V1, V2, ...V10.
Parts: Pt1_v1, Part1_v2, ...Part1_v10.
Assemblies: As1_v1, As1_v2. ...As_v10
Drawings: drg-Pt1_v1, drg-Pt1_v2 ...drg-Pt1_v10
But this doesn't work (not very well anyway) as changes occur for different elements in different versions. In versions 1 to 10, part 1 could be identical. 10 drawings showing the same part! Your suppliers are confused. Your factory is confused.
This is why we have revisions. We only want to flag when a change has been made.
I keep thinking of a video analogy.
Each video frame is a version of the workspace.
Each document Element (parts, assemblies, drawings) are like the pixels in the video frame.
The properties of each pixel (colour and brightness) change the way that Elements of a doc change through each version. (geometry or properties)
In a video, some pixels will not significantly change for long periods of time.They'll remain the same colour through many frames.
Don't some video codecs take advantage of this fact to allow higher compression levels? looking at the pixels and only recording the changes?
Could Onshape do the same? Intelligently decide if an element (part, assembly, drawing) has changed? And revision bump (or not) accordingly. Can we get the AI's working on this please?
I'm just rambling now so I'll stop.
This would be equivalent (in Windows or PDM) to having to create a version of and entire Folder in order to release a part+drawing in that folder. And for Onshape this might not be a problem in terms of Storage, but for a user the interaction is the same.
Onshape, Inc.
This would work, IMHO it's all about generating Data with intent. If I'm not modifying an element it should not generate new entries (at least not visible to the user).
This is the problem that I have with the current Release Management process. If you bump the revision of an assembly, it bumps the revision of all the parts in that document even if they don't have any changes. To understand why that is a problem, here is an example:
Example Situation
The BOM on all of our assembly drawing lists the revision of each part, so that everybody is on the same page as to exactly which part is supposed to be used. Now lets say I have an assembly with 10 unique parts that exist in the same document as the assembly, and I need to make a change to 1 part.
Scenario 1 (Current Onshape Release Management)
I make the change to the part and bump the revision of the part and drawing.
The assembly is also revision bumped since it needs to show that it's using the newly updated part. When the assembly is revision bumped it also automatically bumps all of the other parts as well. Because that happens, all 10 of the part drawings would need to be handed over to manufacturing and production since if the assembly calls out 'Rev B' for a part, they need to have a drawing for 'Rev B'. This would likely then be followed up by them questioning me as to what has changed on the parts because they cant find anything different.
Scenario 2 (Improved Situation)
The assembly is also revision bumped since it needs to show that it's using the newly updated part. No other parts are revision bumped because no changes to them were made. Manufacturing gets handed 2 drawings (1 part and 1 assembly) showing the changes. Job done.
Currently the only way to approach Scenario 2 is to either use the steps @Alexei_Pittowicz outlined in the original post, or move all of the parts into their own documents. Either approach (along with Scenario 1) is a lot of extra steps.
I would like to see improvements in the release candidate functionality (which I'm sure the onshape team is working on anyway!)
If I have released a drawing with an embarrassing typo...
...I want to correct it VERY quickly and "up-revision" (or "bump") the drawing WITHOUT bumping the referenced assembly and parts. I know this is possible now, but I would need to update each drawing view to reference a version.
I may still be at an early design stage and therefore would like the drawing to keep showing the main workspace so that any changes to parts can be more immediately shown in the drawing.
It would be good if I could leave the drawing views showing"MAIN" but on release, have the "super-AI-magic-candidate-dialog" go look to "see" if an element has changed since the last revision. (ie compare the element in the main workspace with the latest revision) and if there is no difference, it doesn't revision bump. Or at least asks me sarcastically: "are you sure REALLY want to up-revision this part when it's exactly the same as the last time? Hmmm??"
I do appreciate that further into a project, the changes become less frequent and it's good practice to update assemblies and drawing views to reference revisions and versions. Not least because of the speed increase across the system.
"...This would likely then be followed up by them questioning me as to what has changed on the parts because they cant find anything different..."
This is the nightmare scenario that we're all trying to avoid. If I had to point to the single most important function of Release Management, it would be that it prevents exactly this situation.
Flow through/carry over of the released state would need to be introduced which would essentially replace the multi stepped approach that Alexei proposed. For example, if I release a drawing and the corresponding part that part is now in the "release" state in the main version of the document and the drawing references the released part. If a user attempts to make a change to it a warning pops up notifying them that it is released and if they accept then the drawing changes to the latest version and the part is no longer indicated as released.
I understand that these "snapshots" of the document need to be taken to capture the released state, but currently they muddy up the document version tree and make it hard to navigate. I wish that the "snapshot" could be taken behind the scenes and not specifically displayed on the version control tree. Again this would need some additional environment to view/navigate the releases.
If I come-of as negative or like I'm ranting, is because it seems (from my perspective) that Release Management is being too tailored to satisfy the end-user(designer). In my experience End-Users typically don't have business process needs (workflow) in mind, they will always request freedom of operation, which does not result in a well managed environment.
Our work around is still not sufficient, as documents default to a workspace view rather than a version and users must navigate through the version manager to find the Production version - often they forget and end up printing out an in-process drawing.
