AddInstance import issues with Configuration Table Part Studio
eric_ma454
Member Posts: 14 ✭
Hi all,
Recently, we have had issues with a specific part studio that we have been trying to import and rotate at multiple points. The part studio is a pipe elbow with specific configurations that dictate its diameter and size. We have been having trouble since the part studio seems to not import correctly. Furthermore, we're unsure how to create a precondition that lets the user choose the configuration to import. If anyone has any insight onto the importing issues, as well as the configuration steps, that would be greatly appreciated.
Elbow(part studio called "elbow):
Instantiator:
https://cad.onshape.com/documents/740e6a14f9b0e5df6b16a58a/w/ce74bd2e6b57ecc8bb2a6914/e/0ca08a2379ad29306245682f
Best,
Eric Ma
AguaClara Cornell
Instantiator:
Best,
Eric Ma
AguaClara Cornell
MBartlett21
Member, OS Professional, Developers Posts: 2,064 PRO
For the configuration parameter, you need to edit the featurescript ids and use them with "_conf" added onto the end.
Please see this post by @kevin_o_toole_1
https://forum.onshape.com/discussion/9001/configurations-update-edit-featurescript-ids
It has an example document that uses configs1 -
Jake_Rosenfeld
@eric_ma454
Personally, I find that the `vector(x, y, z)` interface is easier to use than `vector(value is array)`, but it just depends on how your input is coming.
The difference I was trying to point out is the following:const positionVector = vector(1, 2, 3) * inch; // This is the position vector of a point in space const anotherPositionVector = vector(1 * inch, 2 * millimeter, 3 * centimeter); // Another position vector const directionVector = normalize(vector(1, 2, 3)) ; // This is a direction vector const anotherDirectionVector vector(5, 6, 7); // This is another unitless direction vector, it's just not normalized.
The addInstance function takes a Transform, which can be constructed using a rotation matrix and vector translation, but the toWorld and fromWorld will allow you to construct these Transforms directly (all my apologies for mentioning the wrong functions in my above comment, I've gone back and edited it to use the correct function calls).
Here is to code that I was proposing you use:// --The inputs you've mentioned you already have-- const sourcePoint = ...; const destinationPoint = ...; const sourceDirection = ...; const destinationDirection = ...; // --Constructing the transform and using it-- // Use the direction you already have as the Z direction (for alignment) of the coordinate system, and pick an arbitrary perpendicular vector // as the X direction (to determine the spin). const sourceCSys = coordSystem(sourcePoint, perpendicularVector(sourceDirection), sourceDirection); const destinationCSys = coordSystem(destinationPoint, perpendicularVector(destinationDirection), destinationDirection); // There is a shorthand to construct a coordinate system if you do not care about the x direction: // const sourceCSys = coordSystem(plane(sourcePoint, sourceDirection)); // This shorthand could be useful if you don't end up caring about the spin, but I wanted to show you the longhand in case // you want to start playing around with the X direction to determine spin. const xform = toWorld(destinationCSys) * fromWorld(sourceCSys); addInstance(..., { ..., "transform" : xform, ... }); <br>
Hopefully it is a little clearer now what to do. Once you use the code above, you may find that the spin of your instanced part is all wrong. If that is the case, you will want to be more explicit about the X direction in `sourceCSys` and `destinationCSys`, either by making your user define a mate connector, or by doing some smart inferencing. If you get stuck on that step, we can discuss again
Jake Rosenfeld - Modeling Team1
https://cad.onshape.com/documents/de0b979bd2526029daafe060/w/8043876c6f38336511d43098/e/7a6d9c6a8583cdf983aee11e
With the FeatureScript I linked, it shows examples of how to import to a custom coordinate system and how to implement configurations
Furthermore, I had a few questions on how you create the precondition for the configurations, specifically where Size_conf comes from, and where I would find that for a specific configuration.
When you say "Vector type", I am unsure of what you mean. A vector can hold a position OR a direction (based on whether it is a vector whose members have length units, or the members are unitless, respectively). In either case, this is not enough to fully define a transformation. Based on context, I assume that the two vectors you have are direction vectors?
Two direction vectors do not fully define a transformation for the following reason. If you imagine a part with an associated source vector, and then have another destination vector, once you get to the destination, you can have any possible spin around that vector. Additionally, because there is no associated position, there is no information about the translation involved in the transformation.
What you need here are two coordinate systems (CoordSystem in FeatureScript). The coordinate systems will have an origin (to determine translation) a z direction (to determine orientation) and an x direction (to determine spin). The simplest way to generate a coordinate system in FeatureScript is by having the user place a mate connector, consume that mate connector as a parameter to the feature, and then to evaluate the mate connector; but there are also interfaces that will allow you to create a coordinate system by hand. Once you have two coordinate systems, transforming points is simple:
(Note that this math is meant to be read from right-to-left: Take the source point, change its basis to the source coordinate system, then take that intermediate representation and change its basis back to the global coordinate system assuming that the basis was the destination basis rather than the source basis.)
So the transform you desire is:
@ilya_baran or @kevin_o_toole_1 may be able to help with the other part of the question if @MBartlett21 does not reply (I think you'll hear back soon though
Thank you for your reply! The Vector I was referencing is the Vector type I found on the SLD, where for instance the function vector(value is array) does the function "make a Vector from an array." The main goal was to align the two pipes of an elbow pipe along two drawn out sketch lines. The code I already have currently has the location, and I have the vectors of the two lines that the pipe should follow. The main reason for looking for a matrix is because in the AddInstance, there's a transform parameter that take in a matrix, for rotation, and a vector, for translation. My main issue is how to convert the two vectors and their normal into a rotation matrix not unlike the math that you mentioned, and use it in the context of the "transform" function found in addinstance.
Thank you!
// --The inputs you've mentioned you already have-- const sourcePoint = ...; const destinationPoint = ...; const sourceDirection = ...; const destinationDirection = ...; // --Constructing the transform and using it-- // Use the direction you already have as the Z direction (for alignment) of the coordinate system, and pick an arbitrary perpendicular vector // as the X direction (to determine the spin). const sourceCSys = coordSystem(sourcePoint, perpendicularVector(sourceDirection), sourceDirection); const destinationCSys = coordSystem(destinationPoint, perpendicularVector(destinationDirection), destinationDirection); // There is a shorthand to construct a coordinate system if you do not care about the x direction: // const sourceCSys = coordSystem(plane(sourcePoint, sourceDirection)); // This shorthand could be useful if you don't end up caring about the spin, but I wanted to show you the longhand in case // you want to start playing around with the X direction to determine spin. const xform = toWorld(destinationCSys) * fromWorld(sourceCSys); addInstance(..., { ..., "transform" : xform, ... }); <br>Hopefully it is a little clearer now what to do. Once you use the code above, you may find that the spin of your instanced part is all wrong. If that is the case, you will want to be more explicit about the X direction in `sourceCSys` and `destinationCSys`, either by making your user define a mate connector, or by doing some smart inferencing. If you get stuck on that step, we can discuss again
Is there any way to import more than one part studio? I understand the form of variablename::import exists, but is it possible to export import multiple part studios in one document, and instantiate/access their configurations separately?
https://forum.onshape.com/discussion/11161/drive-an-instantiator-via-an-enum-input#latest
Is that type of functionality what you're looking for?
Hi Kevin, this is similar to what I was looking for, but both of the imports have configurations. The only way I've found so far to be able to have users choose configuration is to export the imported part studio, but when I use the format of
I'm not able to export the part studio, and can't specify which part studio I'm instantiating at a specific point.
This is not a use case we had in mind when originally implementing configs but I think can see the value. If this is important to you please create an improvement request (for a bonus, link us to a version of a document that demonstrates why this would be useful!)
For now, the best you can do is
- Add enum declarations for everything (e.g. export enum Foo { /* redeclare all the Part Studios options */} )
- Add inputs for those enums (e.g. definition.foo is Foo)
- Remap those enums back to the Part Studio enums (e.g. { "MyInput" : MyInput_conf[definition.foo as string] } )
Naturally, this duplicates some work, but it should otherwise give you the feature you need.Features with references parameters are more flexible and end up with much less frequent changes to the feature code. Depending on your desired feature, you might be able to come up with a workflow that uses one instead.
