Is there a default for degree dimensions.
gerald_comeau
Member Posts: 61 ✭✭
I am doing the steel rim exercise in self paced courses. One step in the exercise requires an angle of 30 degrees in a circle. Using the dimensions tool I was unable I was unable to get a 30 degree reading by entering the the number 30 in the space shown. By trail and error I came upon the idea of entering "30 degrees" in the space provided with the dimension tool.
Here is a link to an image showing what I ended up with https://cad.onshape.com/documents/bcb959307f1ecd7ebd253531/w/3093cabc90ee1c93f7bcc076/m/9dc6d2420385c6887139efe9/e/2e765a7eb33c054d5f1c9d0f
I believe I got the 30 degree angle but it is written as 0.524 radian. I find that a little awkward. Illustrations of angle measurements show angle in degrees with the degree symbol. Is there some way I can get the angle reading shown as 30 (with the degree symbol)
I also tried to save versions but could can get only the initial image to show. I don't know if this is any good but here is the link anyway.
https://cad.onshape.com/documents/bcb959307f1ecd7ebd253531/w/3093cabc90ee1c93f7bcc076/e/2e765a7eb33c054d5f1c9d0f
I sent it to clipboard but don't know where to find my clipboard.
NeilCooke
Moderator, Onshape Employees Posts: 5,927
The units of your document are mm/rads/kg. You can set the units of the current doc from the “hamburger” menu top left (3 bars). Change the units to degrees and everything will be OK. Also check your default units - click on “my account” under your picture top right, then look in preferences.Senior Director, Technical Services, EMEA9
