Add vs New Extruded Part for Subtraction etc
william_holden959
Member Posts: 34 ✭✭
Even though I've had an account, I'm finally diving-in (recently from Solidworks). So, I'm new.... I really need the part studio top-down design concept and am liking the concept. I need two cylindrical parts that connect on the edges that provide an adjustable gap between them when you turn one against the other. The profile of the edge has to have "steps" so they can't slide out of adjustment. I'm just trying to make a matching part and do a subtraction. Any help/advice is appreciated. (On a different note, it'd be nice if there was a multi-segmented helix. No need to get degrees or clockwise vs counterclockwise, just pick a point on an existing helix to add pitch and turn. And maybe be able to add filets to the profile?)
https://cad.onshape.com/documents/7ad64ad01976b9fb8b394990/w/c1ded4c1c3a49011d881d699/e/c5426a8ed6f39451e759b186
Jake_Rosenfeld
@william_holden
You need to change your extrude to "Solid" rather than "Surface", and use "New". Then in the boolean, you can do "Subtraction" with the blue part as the "tool" and the grey part as the "target", making sure to select "keep tools" so that the grey part is not consumed.Jake Rosenfeld - Modeling Team5 -
Jake_Rosenfeld
You also may want to not use "Offset all" in favor of just offsetting the top faces that you care about offsetting (otherwise the side faces are offset as well and the geometry is odd.)
I copied your document and made the changes as described
https://cad.onshape.com/documents/2be35d16a23f6d4eab635755/w/53059868b6705c634fdeebd4/e/60a5a69a43a57025ef8d7d3f
Jake Rosenfeld - Modeling Team2 -
Jake_Rosenfeld
@william_holden959
The face will not be selectable in "surface" mode, It will only be selectable in "solid" mode. If you pre-select the face and then press the Extrude button, it will automatically be in "solid" mode, but I suspect you got into "surface" mode by pre-selecting the edge and then pressing the Extrude button.
Additionally, if the face is not there at all to select, you may have to "show" the sketch by clicking the eye next to the sketch feature in the feature list (It will only show up if you hover your mouse over the sketch feature), and you may have to hide certain parts (eye button in the parts list) to get at the sketch once it is shown.
To select the offset faces I had to "hide" part 2 temporarily (while the feature dialog was still being edited), select all the top step faces, and then show part 2 againJake Rosenfeld - Modeling Team1 -
MBartlett21
Member, OS Professional, Developers Posts: 2,063 ✭✭✭✭✭
You can.william_holden959 said:On another tangent (figurative), it appears that I can't do an extrude/cut beginning at an offset distance.
You can add a second direction and click the opposite direction button for it.1 -
Jake_Rosenfeld
@william_holden959 @MBartlett21
Oh how dense I am! I'm actually the one who implemented extrue-up-to-with-offset and then failed to realize it was the right solution for this case...
I've created a version in the same document, and made some edits to reflect the better way!
(In addition to what M. said, I've also backed the plane up an additional 4mm so that the extrude only needs one end position instead of two. Extruding with offset has a quirky behavior that if the offset pushes the faces through to the other side of the profile, the extrude will fail
Feel free to post that document link here also if you want someone to take a look
