Configurations
https://cad.onshape.com/documents/20b7ed88dc59162296b5eb8b/w/a27f60c38cdafae14413fc59/e/aef92d9dadf7f2cfa23c1440
If possible could someone please give a little advice. I am trying to get to grips with configurations and I am using the face plate shown on the above URL. As can be seen I have 8 flanges including holes, My problem is I also want to produce a face plate with 12 flanges. I have managed to configure all the required details for a 12 flange plate which work fine. However only 8 flanges appear when I choose the 12 flange configuration.Where am I going wrong? Any help would be appreciated.
best regards Brian.
best regards Brian.
NeilCooke Moderator, Onshape Employees Posts: 5,848
With the new auto-complete, you don’t need to type in # first. You can just start typing the name.Senior Director, Technical Services, EMEA6
https://cad.onshape.com/documents/934f393e6aad1ad505d205ed/w/b7fa124dcceea8fd38f62532/e/8881140c94f2863f5156fa1d
It appears you can't configure the quantity of the sketch circular pattern and it wouldn't allow me to plug in the variable so I had to make a separate feature for the cutout.
Cris not had a lot of time but been trying to copy your example but cant seem to make it work. Could you have look at the above URL to see where I may be going wrong. thankyou Brian.
