Why Cant I edit imported DWG files in Onshape?
GeeGee Member Posts: 5 PRO
I have Imported some of my 2 D dwg files into my document and am unable to cut and past these parts to fit on one of my Onshape models? When  import the Dwg file or Dxf it shows the file but wont let me work with it unless I buy an add on? I was told that I could import my 2 d drawings and work with them in my modeling? What am I missing?
Any help Much appreciated,
Gee
  • GeeGee Member Posts: 5 PRO
    Thanks Tim I appreciate the assistance.
    Gee
  • timandrewstimandrews Member, Moderator, Onshape Employees Posts: 18 image
    @Gee - Welcome to the forums! Once you upload your DWG or DXF file into Onshape you can use it in your sketch with the "Insert DXF/DWG" tool.
    Gee
