Improvements to Onshape - February 11th, 2019
24
  • APD
    APD Member Posts: 40 PRO
    lougallo said " Exploded views are on the radar and hope to get it to you as soon as we can."
    Thanks for the update Lou, looking forward to that.
  • Ryan_Almeida
    Ryan_Almeida Member Posts: 9 PRO
    Woohoo!  I've been dragging my feet on creating the assemblies for my configurations.  Just in time, it should be way easier now!  Thanks so much.  Awesome work as always
  • Marc_Miller
    Marc_Miller Member Posts: 111 ✭✭✭
    Love the variable name autocomplete.  Thank you for more great updates.
  • michael_corsetto
    michael_corsetto Member Posts: 6 EDU
    Is it possible that this update broke some 3dconnexion Space Mouse functionality? My Space Mouse stopped functioning on certain axis (pan up-down and left-right). The functionality was lost today. My Space Mouse has been great up until now.
    Thanks for the update! Auto-complete variables is great.
  • TimRice
    TimRice Member, Moderator, Onshape Employees Posts: 315 image
    @michael_corsetto
    Please update your 3DConnexion device drivers to the latest version and functionality returns to what you expected.
    Onshape, Inc.
  • romeograham
    romeograham Member, csevp Posts: 777 PRO
    Is there a way to force a Document to update? Currently, some of my existing Documents have the new functionality, and some don't. I understand that it rolls out to existing Documents....
    I'd just really like to try configurations on a certain Document...
  • Jason_S
    Jason_S Moderator, Onshape Employees, Developers Posts: 225 image
    It takes a little bit for us to upgrade millions of documents. Please raise a support ticket to see what we can do to make your experience better.
    Support & QA
  • David_Bone
    David_Bone Member Posts: 47 ✭✭✭
    Amazing set of updates!
    I know I'll be using most of these regularly.
  • Effendi_H
    Effendi_H Member Posts: 19 ✭✭
    Awesome!
    Thanks,
    Effendi H.
  • MBartlett21
    MBartlett21 Member, OS Professional, Developers Posts: 2,064 ✭✭✭✭✭
    romeo_graham392 said:
    It seems that you can't configure the Name property of an Assembly...Is this a limitation? Or is there another way to end up with a different Assembly Name for different Configurations. Other properties seem to be available, but not Name.
    @romeo_graham392
    Here is a IR: https://forum.onshape.com/discussion/11115/configure-assembly-name/#latest
  • romeograham
    Thanks @MBartlett21 !
    Voted.
  • jakeramsley
    jakeramsley Member, Moderator, Onshape Employees, Developers, csevp Posts: 669 image
    Jake Ramsley
  • romeograham
    Thanks @jakeramsley I can understand that issue. @MBartlett21 started a IR: https://forum.onshape.com/discussion/11115/configure-assembly-name/#latest for this.
    The thing is, it makes total sense to have the Assembly Name different if the config is different...Just like a configuration of a part.
    Thanks!
  • MBartlett21
    @bradley_sauln
    Is there a link to the Configurable Computer Chassis document?
  • 3dcad
    3dcad Member, OS Professional, Mentor Posts: 2,482 PRO
    If I have simple configurable part with say X-dim, Y-dim and type A or B. Then I create assemblies using different values and now they are burried into sub-assemblies inside assy-configs.
    When whole product family is finished, I begin with drawings. How can I get single part visible in main assembly with the exactly same configuration into drawings?
    It is quite important that production drawings follow same parameters (dimensions) used in assemblies.
  • MBartlett21
    @3dcad
    I think you can right-click on the drawing and choose to create a drawing of the part
  • Josiah_Harthcock
    Josiah_Harthcock Member Posts: 57 PRO
    Way to go team!
  • emagdalenaC2i
    emagdalenaC2i Member, Developers, Channel partner Posts: 867 ✭✭✭✭✭
    Un saludo,
  • jakeramsley
    Hi 3dcad,
    As MBartlett21 said, if you create a drawing by selecting the part in the assembly then it will make the drawing of that part in that specific configuration.
    Jake Ramsley
  • valérie_Vercruysse
    valérie_Vercruysse Member Posts: 2 ✭
    I just used the configuration in assembly without knowing that it was just new ! I used to work a lot with the configuration with SW , so I took the configuration training on onshape and thought that it was just the same for part studio and assembly. I tried this morning and it works great . I did some drawings with BOM - very easy so switch from one configuration to another one ( just click on one view and that's it - with SW I had to pick on every view that was not linked) . For the moment I just have a little problem with the BOM : it switch to the right config - the name follow too but not the part number . I can tell you assembly configuration just make you win a lot a time !
  • john_mcclary
    john_mcclary Member, Developers Posts: 4,102 PRO
    I'm not winning in vegas, at least there is a huge win with Onshape when I get home!
    Assy configs!
    Var auto complete!
    Section view depth!
    Can't wait to try it all out
  • florian
    florian Member, OS Professional Posts: 110 ✭✭✭
    edited February 2019
    @NeilCooke is there a plan to make the linear pattern in assemblies fully parametric and based on existing geometry? In your example, I would definitely want to pick the distance of the USB ports as a reference from the housing. If someone will change it in the Partstudio, how does the ASM keep up?
    And finally: Variable completion :smiley:
  • NeilCooke
    NeilCooke Moderator, Onshape Employees Posts: 6,103 image
    @florian I am not aware of any “reference pattern” type capability in the works. It’s a good idea though. Can you create an IR?
  • 3dcad
    .. create a drawing by selecting the part in the assembly then it will make the drawing of that part in that specific configuration.
    Is this the ideal workflow? It creates new drawing tab for each part..
    My current workflow is to create drawing from main assy as frontpage, then add parts into separate sheets under same tab.
  • dan_gilson427
    dan_gilson427 Member Posts: 1 ✭✭
    I actually punched the air when I read about variable name autocomplete.  Love your work!
  • owen_sparks
    owen_sparks Member, Developers Posts: 2,660 PRO
    Yes!  Used it for the first time today and felt the same.  Before even if you could remember the name you still had to remember the case of all the letters, this is so much sweeter!
    O.S.
  • john_mcclary
    Yes!  Used it for the first time today and felt the same.  Before even if you cold remember the name you still had to remember the case of all the letters, this is so much sweeter!
    O.S.
    Hope it works for fs pushed vars, tired of going back and forth to my globals fs to check names
  • ilya_baran
    ilya_baran Onshape Employees, Developers, HDM Posts: 1,273 image
  • gerhard_swanepoel
    gerhard_swanepoel Member Posts: 29 PRO
    Again - great improvements! Especially assembly configs. Variable inputs also quite nifty. Thanks!
