How do I stretch a panel in a single direction (y) from the when it has been extruded in (z)?
I've created a panel with specific features such as lightening holes and slots that I need to stretch from the middle in a single (y) direction or axis. The panel was extruded in the z direction. I don't want to stretch from the ends as that may distort the existing features. I'd like to add a few inches to the middle of the panel as it can grow symmetrically in a single axis.
owen_sparks Member, Developers Posts: 2,660 PRO
In that case I'd create some planes, split the part, transform the outer parts into place and then extrude between the gaps to join it all back together again.BTW it would be easier to understand exactly what you're after with a link to the document or a screen grab.Cheers,Owen S.Business Systems and Configuration Controller
HWM-Water Ltd5
that would increase the size of your panel
-OR- if the part is symmetrical, cut it in half, use the Transform feature to move it by the distance you want, create an extrude to fill in the gap that was created, then mirror the whole thing.
