Calculate Bounds
I use onshape to prepare parts to Cam when I do so I do create a stock That in close the model
and I did find this very nice featurescript. Called Calculate Bounds
The only problem with this script is that I cannot control if I want to more offset in X or Y or Z.
Do someone now how you can add an offset tab. maybe if you wanna do a symmetric offset also would be nice and maybe also if you can choose what kind of material you are using and can you export this information to an excel file.
I know this is a lot of questions. thanks in advanced
Kim Salvesen
MBartlett21 Member, OS Professional, Developers Posts: 2,057 ✭✭✭✭✭
@NeilCooke
It was a FS that both @Jake_Rosenfeld and me worked on.
@emagdalenaC2i
I think there will be some very useful improvements to it soon
Please see highlighted above
I have used the algorithm from http://sffsymposium.engr.utexas.edu/Manuscripts/1999/1999-019-Chan.pdf
The sheet metal flat pattern bounds is now faster as well5
Thanks Neil for the fast answer
I do know about that but, I want to customize the script so I don't need to do all those extra step specially not hundreds or parts. so if somebody can point me in the right direction I have already customize the script a little
but I don't know how to implement the offset in the picture
https://cad.onshape.com/documents/631672dc5e8a27c212e0e019/w/1c75cca3d100109fbb97dccc/e/be87f9334492ecff4c1485bd
I think it's quite old and it's possible that you can reduce the code, but it has quite a few very useful options
@emagdalenaC2i
