Calculate Bounds
kim_salvesen_kim_salvesen_ Member Posts: 4 PRO
edited February 2019 in Community Support
Hello
 I use onshape to prepare parts to Cam  when I do so I do create a stock That in close the model
and I did find this very nice  featurescript.   Called Calculate Bounds
 The only problem with this script is  that I cannot control if I want to more offset in X or Y or Z.
Do someone now how you can add an offset tab. maybe if you wanna do a symmetric offset also would be nice and maybe also if you can choose what kind of material you are using and can you export this information to an excel file.
 I know this is a lot of questions. thanks in advanced
Kim Salvesen
