FS error "Duplicate top level symbol name 'build' help?
Hi folks.
It's about time I started looking at FS but I'm falling at the first hurdle.
This file contains the following code:-
It's unhappy and is throwing "FS error "Duplicate top level symbol name 'build'.
If I comment out either of the imports it's happy. They point to different partstudios in the same external file.
What have I screwed up?
Cheers,
NeilCooke Moderator, Onshape Employees Posts: 5,844
Both of those imports (part studios) have a build function so that’s the duplicate. Are you going to instantiate them? If so, define a namespace for each e.g:
HEATSERT::import ...
VOID::import ....
Then precede any reference to them with this namespace. If you’re having trouble i’ll Make an example.Senior Director, Technical Services, EMEA5 -
owen_sparks Member, Developers Posts: 2,660 PRO
Hokay, if I set them up like this all is well:-Cheers, Owen S.Business Systems and Configuration Controller
HWM-Water Ltd0
VOID::import ....
