Connecting surfaces
dare_trivi
Member Posts: 5 EDU
Dear all,
I'm trying to learn how to work with CAD, but got allways this problem. What do I wrong, that this 2 parts (surfaces) are not connected as the other (blue) site? This gray part should be like the other blue site.
Thank you for helping me!
tim_hess427
Member Posts: 648 ✭✭✭✭
It looks like your document is not public, so I am not able to open it and see what is going on. However, there are two things that you should check:- If you are extruding from a sketch to create a new feature that should be connected to the base feature, make sure you select "Add" in the extrude dialog box.
- Make sure the "Merge Scope" section includes all of the correct parts that should be connected to your new feature.
I hope this helps!2 - If you are extruding from a sketch to create a new feature that should be connected to the base feature, make sure you select "Add" in the extrude dialog box.
