Using previous sketch to define/constrain another..
steve_maiettasteve_maietta Member Posts: 54 PRO
Can I specify a sketch (earlier up in the tree) for use in defining or constraining another sketch?  For example "sketch 1", make an hexagon with a circle in the middle, extrude it (a simple hex nut solid) and then create another "sketch 2" that references the circle (bore)?
can't seem to find this..
thanks!
~Steve
    steve_maietta I do this all the time, Just make the sketch visible and simply constrain the geometry from one sketch to the geometry on the other.
    Yes, you can use external geometry including other sketches to constrain sketches.  The constraints and dimensions will have to be manually applied though.
    Jake Ramsley
  • steve_maiettasteve_maietta Member Posts: 54 PRO
    Hmmm..  I tried highlighting the Sketch 1 and using it but it wouldn't actually constrain..  Is there some buttons to specify a constraint?
    Thanks, I saw the constraint buttons but didn't know how to use them..  This clears it up!
    Got it working..   Now, is there a way to copy sketch geometry and "paste" it into another sketch?
    Gents, the tool for this is the "Use" tool in the sketching menu.  Perfect solution answers all my questions.
