how can put chain on gear?
jan_rakovský
Member Posts: 2 ✭
i try to find way how can i put chain on gears. chain have 45 parts. how can add mate between 1 and 45 parts?
my way evidently do not work...
john_mcclary
Member, Developers Posts: 4,001 PRO
I would make that in a part studio with Curve pattern. then insert them into the assembly, then use group mate to lock them in.
https://cad.onshape.com/help/Content/curvepattern.htm?Highlight=curve%20pattern
https://cad.onshape.com/help/Content/mategroup.htm?Highlight=group%20mate
Or instead of separate pieces of chain, you could boolean union them together in the part studio, then insert into the assembly as a single part. (would be better for performance.
https://cad.onshape.com/help/Content/booleanparts.htm?Highlight=boolean
5
