Dividing Lines
famadorianfamadorian Member Posts: 390 ✭✭✭
Is there any way to hide these dividing lines on a part?
Like here, objects in blue are all the same part, but it still shows a dividing line, because of how I've constructed it, but can I hide these lines, when it's the same part?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,922 image
    If the faces are indeed touching and coplanar, those lines will not be there - can you double check the accuracy of your extrudes/sketches?
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    edited February 2019
    Here's an example:
    https://cad.onshape.com/documents/858ff026c133c7ada912a325/w/b60f59ef487e442687503ad8/e/e7773ff71f41fcf013eb2cec
    Here is from one angle, where we don't see the dividing lines on the top of the cabinet:
    and here's from another angle:
    @famadorian those are what are known as "bleed-through" lines and are not really there at all. It is the graphics tessellation quality. Increasing tessellation quality has no effect so you should probably report that as a bug.
