Using Onshape to take the CWSA or CWSP certification test
terry_rorisonterry_rorison Member Posts: 6 EDU
Anyone used Onshape to take the CWSA or CWSP certification test.  If so, what was your experience?
  • michael_mcclainmichael_mcclain Member Posts: 198 PRO
    edited March 2019
    I am a CSWP and as far as I can remember you need to take it in Solidworks. I would not use Onshape for this because it is a certification of Solidworks knowledge and skills. Using another program to get certified in Solidworks is a bit like cheating.
    Here is the webpage: https://www.solidworks.com/sw/support/797_enu_html.htm
    It is a difficult test so I strongly suggest to take a course to prepare and to try the practice exam. Good luck!
  • emagdalenaC2iemagdalenaC2i Member, Developers, Channel partner Posts: 864 ✭✭✭✭✭
    @michael_mcclain Actually I can take the CSWP and pass it just using a Google Spreadsheet, and no... it is not cheating I just don't need to use SolidWorks to answer all the questions.
    I am CSWST - Certified SolidWorks Support Technicians, CSWI - Certified SolidWorks Instructor and a few more
    Un saludo,
    @emagdalenaC2i ok I'm probably mistaken. It's been a while since I took it and I don't fully remember the format. I do still feel that using a different program for a competency test doesn't feel right, but to each his own.
