Notepad in onshape?
Is there a notepad app for onshape? Or featurescript?
I'd like to have a tab with a big textfield that I can use for ideas, todo's,...
Currenly I'm using a drawing with a big text field, but that's a bit of a hack.
If not, can I program an app or feature for that for personal use?
In order to create a tab, you need to create an app, right? Featurescripts cannot create separate tabs?
erik_bongers said:Featurescripts cannot create separate tabs?You can use featurescript tab, just add one and type text as code comments inside<div>/*</div><div>multiline_comments</div><div>*/ </div>
or//single_line_comment
7 -
romeograham Member, csevp Posts: 714 PRO
You can also use the excellent Link Tab (by @lougallo ) from the App Store here: https://appstore.onshape.com/apps/Utilities/DFE73AMQ42NPMVAEQBQVP56QGLCWJ4ALJUBEBLA=/descriptionAllows a Google doc to live in your Onshape Document. Works just like you would like, but has the added benefit of being a live Google doc available outside your OS doc too.
6
(featurescript tab...should have thought of that...)
