Is it possible to multiply a feature in a part according to points from a sketch?
Hi everyone,
I would like to multiply a feature I need in several location in my part.
Is it possible to clone the feature to other places according to points from a sketch?
I am thinking about the feature "Sketch pattern" from Solidworks.
Thank you for your help!
Sylvain
Sylvain
NeilCooke Moderator, Onshape Employees Posts: 5,873
There is no built-in point pattern feature, but there is a custom feature - just add it to your toolbar using the + button at the top of this doc: https://cad.onshape.com/documents/9fca78cb66a0bc83e359eb3e/v/7b8e02af4e9b52af8d3ba60b/e/d7f44d3f530f6db8852edfebSenior Director, Technical Services, EMEA7
This custom feature (https://cad.onshape.com/documents/e02f8da5c872d4d55e30e218/w/41d8b64176967ea1955c14fa/e/78acc1887ae1c49f1407d251), is PARAMETRIC and allows you to being in parts from other part studios and other documents (using the new FS reference capability).
Because its parametric, if the sketch is edited, then more or fewer instances will be created.
It kicks a**!
With regards to FS for assemblies - we talk about it a lot, but nothing that I can state as being company intent. Let's just say 'never say never'!
Here is an improvement request for 'AssemblyScript'
https://forum.onshape.com/discussion/9663/featurescript-for-assembly
https://cad.onshape.com/documents/4c1aba613a40947311bc6d05/w/3a2a6e89b11af1ac81749f98/e/16f4dcf95b4d67030e3eaa4f
Parametric QLV's (the selection box) in all dialogs is something that we would like to do at some point - but that project is not currently scheduled.
So for now, any solution would be a custom feature (nothing wrong with that, they rock).
Your specific request (parametric pattern of a feature) does not exist as a CF currently (as far as I know). If I get bored here at work and no one is asking me to do anything, I could write one - but you can guess the odds of that happening.
That said, you can do it with the Parametric Sketch Pattern CF as follows.
Pattern the plug
Fill-in one of the holes (delete face)
Put a hole feature at the sketch point where the hole was filled in.
Detail that hole in the drawing
