Using Webhooks for Part Translation
I see once you submit a translation job through the API, there are two options;
1-If the requestState is ACTIVE, the translation can be polled until the state becomes
either DONE or FAILED.
2-Alternatively, a webhook callback can be registered for notification of
translation completion.
Now, I've successfully attempted the first method, but the second one would be preferred for obvious reasons.
I can't find much information about webhook callbacks though. For example I don't see in the translation request and entry for webhook ID, nor I know what events are there for creating a webhook.
Request Body (for Create Part Studio translation)
configuration | String | A configuration string indicating the particular configuration that should be translated | N/A | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
formatName | String | Name of format into which this element should be translated. ONSHAPE indicates that the model file should be translated into a Part Studio or Assembly. | N/A | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
includeExportIds | Boolean | Whether to include topology id strings in parasolid output format. | N/A | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
linkDocumentWorkspaceId | String | If storeInDocument is true and linkDocumentId is specified, this specifies a workspace to be used for result storage within the linkDocument. | N/A | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
partIds | String | A comma-separated list of part ids that should be translated. If not specified, all parts are translated. | N/A | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
storeInDocument | Boolean | controls whether the translation is stored as a new element or whether the data is stored as external data (storeInDocument=false). |
Request Body (for Create Webhook)
data (Optional) | String | Data to encapsulate in webhook | null | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
events | String[] | Array of event names for which to register webhook | N/A | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
filter | String | Context for webhook, in one of two forms: "{$DocumentId} = '[did]' && {$WorkspaceId} = '[wid]' && {$ElementId} = '[eid]'" or "{$UserId} = '[uid]' && {$ClientId} = 'cid'" [did] is a document ID, etc., but the components in brackets and the quotes must remain exactly as written, in the same order | N/A | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
options | Object | Options object, with one optional field: collapseEvents, which is set to true/false and says whether similar events should be collapsed into one notification | N/A | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
url | String | URL to which to send notifications | N/A |
