Extrude-Remove up to surface
Hi,
I go on trying OnShape and I would to do a extrude up to surface to remove solid.
In Inventor I used to select the surface directly, and it was recognices as only one surface.
Onshape selects the different parts of the surface and it doesn't be allow me to select all.
Thanks for any help
Thanks for any help
Below the feature list there is a parts list. In the "surfaces" section you will find your surface, and it will have the same eye next to it.
