Regex in search bar
Henk_de_VlaamHenk_de_Vlaam Member, Developers Posts: 265 ✭✭✭
Is it possible to use regex in the main search bar on top of the Onshape screen, right of the Onshape logo?
Example: search all objects with ".drw" at the end of the name.
At this moment the result is, all objects that contain ".drw" anywhere in the object name, so also when it is in the middle of that name. Normally one can use "*.drw", but in OS the '*' has no function.
Henk de Vlaam
