Multi Mate Question
Hopefully the video is clear enough...I realized I misspoke in the vid and would like the existing pivot point to move 'up' and 'down' along another defined mate. Perhaps a pin slot mate without a pin or a slot?
Thank you
http://www.youtube.com/watch?v=NHLh6fRvYAw
https://cad.onshape.com/documents/0dd919364bea73b4a5c650fc/w/b19bfa3dc83ba92b6d837a1d/e/ad47e498f0f51bda806bc389
Thank you
larry_hawes Member Posts: 478 PRO
Question wasn't as clear as it could have been but discovered the 'limits' in the planer mate gave me the motion I was looking for. Thanks very much.http://www.youtube.com/watch?v=GLfXjQ_5BYw
If I am understanding correct, you want the mate to be able to rotate about the blue axis up to the limits of the box as well as traverse along the blue axis to the top and bottom of the box? If so, you don't need to do multiple mates and can use a cylindrical mate (https://cad.onshape.com/help/Content/mate-cylindrical.htm).
In essence:
If you have more questions about assemblies, I recommend taking our Onshape Assemblies self-paced course which is available here: https://learn.onshape.com/courses/fundamentals-onshape-assemblies. It will take you through the fundamentals of inserting, instancing, and mating assemblies.
