Extrude Between Two Limits/Distances
Apologies if this question has been asked before, but I couldn't find an answer to it.
Is there any way to extrude a sketch between two limits? i.e. +5mm to +8mm
At present it only seems to extrude from 0mm to any distance you specify, but not between two limits. I am coming from a Unigraphics NX background where this is quite useful.
1
brucebartlett Member, OS Professional, Mentor, User Group Leader Posts: 2,145 PRO
No this is not in the extrude feature, I have also looked for this. I would say however don't use it much in other CAD. Onshape alternative is to select the face at the sketch and do a Move face or Extrude Remove after the first extrude. Bit of extra work and you end up with 2 features in the tree but works ok.5
UX/PD/Community Support
Also I'd like to see extrude in an arbitrary (ie not necessarily orthogonal) direction.
Both of these capabilities simplify the feature list as well as the workflow...
