Add dimensions to sketch drawing.
brian_pinder662
Member Posts: 119 ✭✭
Could anyone say if it is possible to add dimensions to a sketch drawing. I have a sketch which I have added to an A3 drawing sheet but has none of the original dimensions as in the part studio. Is it possible to add these original dimensions to the drawing as I would like to use this drawing as a reference.
any help would be appreciated thank you.
best regards Brian.
best regards Brian.
1
NeilCooke
Moderator, Onshape Employees Posts: 5,940
No, you can't insert dimensions from a model or sketch, you have to recreate them in the drawing (with tolerances, etc.).Senior Director, Technical Services, EMEA5
Brian
