Part Missing from Drawing
paul_bartlettpaul_bartlett Member Posts: 91 ✭✭
There are 6 each 1-1/2 tubing squares in this orderly tangle. The drawing only shows 5 in any of the views. Anyone know whats going on?
https://cad.onshape.com/documents/61c933e953d3af55c5624b20/w/762737460990587f321bf1ed/e/02c0e7299dea10a9082e5c27
    NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,396
    Did you create the drawing before adding the 6th? Adding parts to a Part Studio will not automatically add them to the drawing (or assembly). For the drawing to update you must create a drawing of an assembly which in turn must have all parts inserted individually.
    Hard to explain in words. If you try it on a simple example you will understand it better. In essence, do not create a drawing of a Part Studio - only individual parts or assemblies.
    That Was it Thank You
