Is there a way to get specific information of a mate from API?
C_Justin
Member Posts: 16 ✭
Is there a way to get how a mate limit two different parts from API? Like which axis the mate will constraint and how much freedom are allowed on each direction?
Ethan_K
Member, Onshape Employees Posts: 57
There is. You will have to call the assembly feature list API. For example, I made an assembly with a revolute mate limited to 45 degree rotation here: https://cad.onshape.com/documents/cca81d10f239db0db9481e6f/v/369ac699891d9659ce2d42ba/e/32fbe5d87f9b2777a37ddee9 . When you call this endpoint (just put it into your browser that is signed in to Onshape): https://cad.onshape.com/api/assemblies/d/cca81d10f239db0db9481e6f/v/369ac699891d9659ce2d42ba/e/32fbe5d87f9b2777a37ddee9/features you should get the following: (I deleted the nonessential bits for brevity){"features": [{Under features[0]["message"]["parameters"][2]["message"]["expression"], you'll see my z axis offset of "-0.25 in", and under features[0]["message"]["parameters"][5]["message"]["expression"], you'll see my z axis axial limit of "45 deg". Note that these parameter lists don't have a guaranteed order, so don't hardcode the location (here, 2 or 5). Instead, you should filter based on the type, and subsequently the parameterId. For the offset, the type is "BTMParameterQuantity" and the parameterId is "mateOffsetDistanceZ". For the limit, type is "BTMParameterNullableQuantity" with a parameterId of "limitAxialZMax". Hope that makes sense!
"type": 64,
"typeName": "BTMMate",
"message": {
"mateConnectors": [],
"version": 2,
"featureType": "mate",
"featureId": "MHRrbsJgjRWu3+Iaf",
"name": "Revolute 1",
"parameters": [
"type": 145,
"typeName": "BTMParameterEnum",
"message": {
"enumName": "Mate type",
"value": "REVOLUTE",
"namespace": "",
"parameterId": "mateType",
"hasUserCode": false,
"nodeId": "pfmse+zfxKRK6dpx"
"type": 144,
"typeName": "BTMParameterBoolean",
"message": {
"value": true,
"parameterId": "mateOffsetEnabled",
"nodeId": "hlflbMRsVZ/Es5eF"
"type": 147,
"typeName": "BTMParameterQuantity",
"message": {
"units": "",
"value": 0.0,
"expression": "-0.25 in",
"isInteger": false,
"parameterId": "mateOffsetDistanceZ",
"nodeId": "J+LuPhxB+1t4vnYa"
"type": 144,
"message": {
"value": true,
"parameterId": "limitsEnabled",
"nodeId": "ZKIZpuNWOeRbZ0dM"
"type": 807,
"typeName": "BTMParameterNullableQuantity",
"message": {
"isNull": false,
"nullValue": "",
"units": "",
"value": 0.0,
"expression": "0 deg",
"isInteger": false,
"parameterId": "limitAxialZMin",
"nodeId": "KVXmU7kM3+EMaFjq"
"type": 807,
"message": {
"isNull": false,
"nullValue": "",
"units": "",
"value": 0.0,
"expression": "45 deg",
"isInteger": false,
"parameterId": "limitAxialZMax",
"nodeId": "OxNBRDEYP++UdZT8"
"type": 144,
"message": {
"value": true,
"parameterId": "primaryAxisAlignment",
"nodeId": "Af/1L8J6jK45NqU/"
"type": 145,
"message": {
"enumName": "Reorient secondary axis",
"value": "PLUS_X",
"namespace": "",
"parameterId": "secondaryAxisAlignment",
"nodeId": "It64Nf/o+SfvHv/S"
"suppressed": false,
"namespace": "",
"subFeatures": [],
"returnAfterSubfeatures": false,
"suppressionState": {
"type": 0
"nodeId": "MHRrbsJgjRWu3+Iaf"
"featureStates": [
"key": "MHRrbsJgjRWu3+Iaf",
"value": {
"type": 1688,
"typeName": "BTFeatureState",
"message": {
"featureStatus": "OK"
"isComplete": true,
"serializationVersion": "1.1.16",
"sourceMicroversion": "e6688ceaaf1f929e8d0bcd47",
"rejectMicroversionSkew": false,
"microversionSkew": false,
"libraryVersion": 0
6
{"features": [
{Under features[0]["message"]["parameters"][2]["message"]["expression"], you'll see my z axis offset of "-0.25 in", and under features[0]["message"]["parameters"][5]["message"]["expression"], you'll see my z axis axial limit of "45 deg". Note that these parameter lists don't have a guaranteed order, so don't hardcode the location (here, 2 or 5). Instead, you should filter based on the type, and subsequently the parameterId. For the offset, the type is "BTMParameterQuantity" and the parameterId is "mateOffsetDistanceZ". For the limit, type is "BTMParameterNullableQuantity" with a parameterId of "limitAxialZMax". Hope that makes sense!"type": 64,
"message": {
"version": 2,
"parameters": [
"type": 145,
"message": {
"namespace": "",
"type": 144,
"message": {
"value": true,
"type": 147,
"message": {
"units": "",
"value": 0.0,
"isInteger": false,
"type": 144,
"message": {
"value": true,
"type": 807,
"message": {
"isNull": false,
"nullValue": "",
"units": "",
"value": 0.0,
"isInteger": false,
"type": 807,
"message": {
"isNull": false,
"nullValue": "",
"units": "",
"value": 0.0,
"isInteger": false,
"type": 144,
"message": {
"value": true,
"type": 145,
"message": {
"value": "PLUS_X",
"namespace": "",
"namespace": "",
"subFeatures": [],
"type": 0
"featureStates": [
"value": {
"type": 1688,
"message": {
"isComplete": true,
"libraryVersion": 0
