Drawing views
svenolov_nystrom
OS Professional Posts: 64 PRO
The isometric (y) axis view shown in my assembly is rotated and shows in X-axis on the isometric drawing view
Is this intended , ?? or do I have bad luck
If you have drawn it wrong in the assembly, or forgot to "Fix" a part, then it would show in an odd position in your drawing
https://cad.onshape.com/documents/6aa57bfb0b507a2627534a3a/w/6fd2bb994d192cb17da22e10/e/ab18b0318ca6365a9a5d4bb6
You must have started with the ISO titleblock instead of ANSI
From the Camera and Render Options dropdown (the little cube under the View cube) select Named Views:
Set your view, name it, and save it:
You can then select that view when inserting a new view into your drawing:
I didn't realize it either, but this has been available since the 1.63 (released on 2017-05-24).
Hope this helps!
