Featurescript: type checking
jrs_spedley
Member Posts: 71 ✭✭
Just a quickie, I can find an isInteger function and an isReal function (with bounds) but it seems they are more for 'features' rather than programming. Is there a way when parsing an array to check what data type each element is, i.e. isBox, isArray, isString etc?
You can use `is <type>` for this.
Example:
for (var item in someArray) { if (item is box) { ... } else if (item is number) { ... } else if (item is ValueWithUnits) { ... } }Same syntax as the `is` syntax for typechecking function parameters:
function doSomething(context is Context, id is Id, definition is map) { ... }So if you do:
if (item is Vector) { ... } else if (item is array) { ... }orif (item is map) { ... } else if (item is ValueWithUnits) { ... }you will never actually hit the second block of execution.To check what builtin type a certain Type is based on you can search the standard library for `export type <TypeYouAreCuriousAbout>`:
Here you can see that a Vector is just an array with nonzero size.
Thanks for super swift response. I'll go and change everything back now as I've just changed all my arrays into boxes as a work around!
