Part Imports as surfaces
Member Posts: 56 ✭✭
I'm trying to import the "mosquito cad" file from https://www.sliceengineering.com/documentation.   But when I import into onshape it comes in as surfaces w/ no parts.  Any ideas whats going on?
my doc @ https://cad.onshape.com/documents/223146bb463c991c77f7e75c/w/402b902059b2d8c1f282cc00/e/caaab11af1447f9b68150fee
fusion 360 sees the bodies as expected.  Any ideas would be appreciated!
  • Onshape Employees Posts: 727
    In this part e.g. there are several cylindrical patches missing
    Might be a processing issue on our side. I don't know if in Fusion 360 terminology Body necessarily means solid body. May be those patches are missing there as well.
  • Member, Moderator, Onshape Employees Posts: 315
    Just checked out the doc. Using my Fill gaps custom feature you can easily identify holes in imported surfaces and repair them:
    This tool worked quite well on your imports!
    Onshape, Inc.
  • Member Posts: 56 ✭✭
    thx @TimRice !  It worked on the the radiator part your showing.  But I couldn't get it to work on any of the other parts in that import.  here's the doc I was trying it in
    https://cad.onshape.com/documents/223146bb463c991c77f7e75c/w/402b902059b2d8c1f282cc00/e/945684222be4095c25eaa937
    Yes unfortunately it does not work in all cases. Since the feature only accepts one input a set of surfaces like the example below will not work:
    Instead you will have to manually use the Fill or Loft features to bridge the gap between the inner and outer surfaces.
    Onshape, Inc.
  • Member Posts: 648 ✭✭✭✭
    @shai_perednik - it looks to me like your Fusion360 screenshot is showing "surface bodies" and not actual "solid bodies". I know that probably doesn't help much, but to me, it would indicate that the issue is not with Onshape, rather whatever created or exported the model.
    @tim_hess427 ty for pointing that out!  I've reached out to slice eng. and waiting there feedback as to what's going on w/ the model
