Part Imports as surfaces
shai_perednik
Member Posts: 56 ✭✭
in General
I'm trying to import the "mosquito cad" file from https://www.sliceengineering.com/documentation. But when I import into onshape it comes in as surfaces w/ no parts. Any ideas whats going on?
my doc @ https://cad.onshape.com/documents/223146bb463c991c77f7e75c/w/402b902059b2d8c1f282cc00/e/caaab11af1447f9b68150fee
fusion 360 sees the bodies as expected. Any ideas would be appreciated
! 0
Might be a processing issue on our side. I don't know if in Fusion 360 terminology Body necessarily means solid body. May be those patches are missing there as well.
This tool worked quite well on your imports!
Onshape, Inc.
https://cad.onshape.com/documents/223146bb463c991c77f7e75c/w/402b902059b2d8c1f282cc00/e/945684222be4095c25eaa937
Instead you will have to manually use the Fill or Loft features to bridge the gap between the inner and outer surfaces.
Onshape, Inc.
