Animation in assembly
bryan_lagrange
Member, User Group Leader Posts: 945 ✭✭✭✭✭
in General
Is there a way to run 2 animations on 2 different mates at the same time?
I have an assembly that has both left and right and up and down motion and I would like to have both animations run at the same time.
Thank you in advance
Bryan Lagrange
Bryan Lagrange
konstantin_shiriazdanov
Member Posts: 1,221 ✭✭✭✭✭
within Onshape you can only use the method of @john_mcclary for his rubics cube animation, but in general you would better use some another application from appstore for this
5 -
philip_thomas
Member, Moderator, Onshape Employees, Developers Posts: 1,381
@bryan_lagrange - totally doable!
Just as Jake said, you need to create a relationship between the two driving mates using a 'mate relation'.
Then just animate one of them.
If you post a like-example, five guys will jump on it!
Philip Thomas - Onshape1
Maybe as a workaround you could set up a relation (Gear, Rack and Pinion, Screw, or Linear) between the two different systems? You could suppress the relation while actually working, and unsuppress when you want to show a client or make a video.
@Jake_Rosenfeld can you show an example of this?
Twitter: @BryanLAGdesign
