Animation in assembly
bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 866 ✭✭✭✭✭
Is there a way to run 2 animations on 2 different mates at the same time?
I have an assembly that has both left and right and up and down motion and I would like to have both animations run at the same time.
Thank you in advance
Bryan Lagrange
Bryan Lagrange
Twitter: @BryanLAGdesign
    edited April 2019 Answer ✓
    @bryan_lagrange - totally doable!
    Just as Jake said, you need to create a relationship between the two driving mates using a 'mate relation'.
    Then just animate one of them.
    If you post a like-example, five guys will jump on it! :)
    Philip Thomas - Onshape
    @bryan_lagrange
    Maybe as a workaround you could set up a relation (Gear, Rack and Pinion, Screw, or Linear) between the two different systems?  You could suppress the relation while actually working, and unsuppress when you want to show a client or make a video.
  • bryan_lagrangebryan_lagrange Member, User Group Leader Posts: 866 ✭✭✭✭✭
    I have  two pivot points. The goal is to have the unit go left and right and at the same time move up and down.
    @Jake_Rosenfeld can you show an example of this?
    Bryan Lagrange
  • KrzKrz Member, Developers Posts: 68 ✭✭✭
    edited April 2019
    @olaf_huber644 shows how to do it here:
    /Krz
    G
    M
    T
    Y
    EnglishPolishSwedish
    Text-to-speech function is limited to 200 characters
    Thanks guys. Your help is greatly appreciated. This is the most helpful CAD forum around.
    Bryan Lagrange
