Using 'Use' and Possible Alternatives....
I tend to use the 'Use' command a lot to duplicate earlier sketches but then, very often, want to modify the second sketch which requires deleting many many Use constraints before proceeding with the modifications. Is there another way to 'use' a previous sketch as the basis for another sketch without the 'Use' command? Or is it just a difficult task when using this method?
Thank you
http://www.youtube.com/watch?v=KmKJMJnQhWM
https://cad.onshape.com/documents/c7ac382255c4440e75bf4ef3/w/1f3e5ec88beba41434f1492d/e/4acce76f9471456354ecfedd
Thank you
romeograham Member, csevp Posts: 706 PRO
You can't paste it in the same location, but it will retain all "internal" constraints, including dimensions, constraints etc. That means that you can pretty easily constrain the newly-pasted sketch to your original sketch (and depending on how many "external" constraints are required, it could be very simple). This way you can retain your design intent in the new sketch, but easily put it in the right location.
You can use Coincident between the new sketch entities and the old ones...this at lease will give you only 1 constraint to change per line (as you know, the "Use" command produces 3 constraints: the line, and the vertices at each end of the line).
Good luck!
Romeo5
Good luck!
Romeo
This worked pretty well and will give me another option as well as the other ideas posted.
Thanks for all the help...
