In need of: Keyhole FS
Cris_Bowers
Member Posts: 281 PRO
Finding an existing FS is proving challenging. I would like an FS that will cut a keyhole by defining a major diameter, minor diameter, slot length, rotation angle, and end type. I think this would be fairly easy for someone that knows what they are doing.
Just model the keyhole body, with configuration parameters, and then use SuperDerive to bring it in at a mate connector location as a cut.
here you go
https://cad.onshape.com/documents/0f1e2c0f49124ab4a671df37/w/894da07d9e5b088b4e37cfee/e/07819bfb3140b4d7fe6f31c0
Select a reference edge, then specify rotation angle relative to that?
or angle based off of sketch plane? based on the sketch plane normal?
The reference edge currently is along the length of the narrow slot, you can fill that all in first, in fact I may move that selection up the UI list, I get confused why there is no slot shown until I remember to click a ref-edge
I've added rotation to the list
THIS is what makes Onshape and this Community so amazing.
Nice work guys.
@john_mcclary , I need a pilot program for a V-212 helicopter
Onshape, Inc.
