Manipulating imported slt files?
 darrin_jones
                    Member Posts: 15 ✭✭
darrin_jones
                    Member Posts: 15 ✭✭
                    I realize now that I've put this in the wrong forum section. feel free to move it to questions, I don't know how...
ok I'm not sure what I'm asking... Here is what I want to do, I have imported an stl file (stormtrooper helmet from thingiverse) that I need to accurately resize for my daughters head. I can use the "scale" in the transform but that it isn't (or at least I don't know how) able to scale so that a specific dimension can be used. I.E. specific head width. with simpler models I just copy the shape creating a new part with the imported file as a template then dimension that. With my limited CAD skills I'm not able to use the imported Stormtrooper helmet as a template.
again I don't know what question I need to ask here...
thanks
thanks
STL manipulation is something we get asked about from time to time.
While we would like to be all things to all people, we are maniacally focused on the workflows of pro users and have a long list of things we need to do for them. STL files are made from brep models (like Onshape, SolidWorks etc) and an Engineer would simply edit the brep and then re-export the STL.
There are free hobby grade STL editors and Autodesk has a fantastic suite of tools for this market - i would point you specifically to MeshMixer. http://www.meshmixer.com/
Good luck!
thanks
@darrin_jones - I have some good news for you!!!
(thank you Neil)
If you share a link to your public document we can help you through the steps of how to scale to an exact size.
thanks Guys!
It looks like the Prusa version of Slic3r does support scaling or re-sizing - see about 1/3 of the way down this page and look for "Scale" or scaling".
https://www.prusaprinters.org/slic3r-prusa-edition-beginners-guide/
Plex Lucky Patcher Kodi
You can check this out: http://apkdodo.com/
Fusion 360 may allow you to do similar, but I haven't looked into it far enough..
Also - if you think of a casting, it might have what, 200 edges?
A 'solidified' STL could have upwards of 500,000? 1,000,000?
How well do you think that would perform in any system?
There are newer technologies coming, but for now, a mesh/cloud dataset should be for reference only.
