I can't get it to work.
Also, why not select all faces of a part or just the part itself?
Doesn't seem to do a thing;)
Could you share it to me too?
I have made some improvements in my copy of it and would like to merge them into yours
My version is here: https://cad.onshape.com/documents/982fc7244bbd0d9a3368d875
@famadorian
My version will automatically select concave faces propagating from the faces that you select, much like the 'pocket' option in create selection
This one deletes some parts of the part, but not all;)
Here's my document (part studio 4):
https://cad.onshape.com/documents/70d70cf1b954c030847ece24/w/de6d8c01c346e92bbbdec2d7/e/36d3ec964060f62ffba9ab9b
link
Also Morgan - you weren't kidding about changing it a bit.
Hope that helps,
I moved the cabinets so that they didn't intersect with the drain and now looks good;)
Why do I see their ghost appearance though? The slider doesn't go any further
I inserted it into the assembly;)
Thanks to you all for solving this;)
That also feels like a causality loop paradox, cause how can I import the parts if I already deleted them?;)
There's no such option to "replace" them with the in-context ones?
What's the proper procedure?
You should have only copied the sink, for the sake of using it as a trimming tool against the shelves.
Which is the problem with in-context / transform copy in place. You are asking the system for a new part starting from this assembly position. But then you have multiple parts in the assembly.
You should be able to just suppress the original cabinets. In-Context only updates when you ask it to, so you can suppress them for now, then in the future you will unsuppress them before you update the context.
Maybe create a checkbox configuration in your assembly that suppresses the parts and their mates, that will make it easier to toggle (I'd name the configuration "in-contex mode")
Now you would need to manage 2 assemblies, doubling your workload
In the above example the taps don't add anything to the cutting process, but they do add overhead to the in-context so let's omit them here and just put them in the main assembly.
ICWUTUMEAN
So, I guess I have to do it again and bring the door with me, into the in-context part studio.
We also don't need to speak about replace the parts and suppressing subparts, cause we modify the specific instance of the cabinet.
It is easier to understand whats happening once you get deeper into parametric systems. Understanding when parts come in and out of existence (new internal I.D.), can be as simple as the order in which you select objects in a boolean, or an extrude add deleting an existing edge... Transform Copy is defiantly one of those cases where a clone (new part with perfectly copied geometry and a new unique internal I.D.) has been brought into existence.
These kinds of things (in-context relations & derives) need to be thought out thoroughly before beginning a large project. Otherwise they can be HARD for you and HARDER for anyone who comes after you if the solution is not obvious. Unfortunately the only way to learn these things is to fail at it many times and take mental notes, and do a little better next time.
First of all, we shouldn't be working on a copy; we should be working on the specific instance of this cabinet
Secondly, as there's no copy going on, there would be no reason for the suppression of a subpart, since we're modifying the actual instance.
https://cad.onshape.com/documents/70d70cf1b954c030847ece24/v/01dabfcdc3d55baced4f9f74/e/8ce4f09a8a2a91930f98d819
Also, when you say "create an in-context sketch", do you mean creating a part studio in context? , cause that's what we've done.
That's like the whole point of this thread, now.
It would probably clear things up if you read the thread.
You say: "I would have edited the cabinets in the context of the assembly". Sure, but you'd end up with copies in the assembly, which kinda sucks.
A proper solution would be to edit the instance, not a copy of the instance.
You can create a context for the original cabinet instead.
instead of creating a new part in contex, right click the cabinet and edit in context.
Although, ou will need to repeat this step for each cabinet. depending on if you modeled each cabinet in a separate part studio..
Ah, think I'm getting there soon;)
Now I'm stumped by this.
I created a context, but why does the "subtract1" still do something, when context is "none"?
